Originally Posted By: SR5
It looks to me like ILSAC and Dexos oils are becoming mid-SAPS oils
Maybe a formulator could better enlighten us, but I seem to recall things jumping around a bit when SM/GF-4 evolved and as SN/GF-5 came in and matured. We had all kinds of concerns about low TBN oils, for instance, and then things started to climb back up. Much the same happened with some of the HDEOs at the time, but higher TBN E7, E9 types became readily available.
It's too bad Imperial Oil's site evolved. I'd be able to show some of those numbers on both the PCMO and HDEO side, since they used to keep old data sheets online. Maybe the Shell site might have something useful, since they do have a few older data sheets available, if you look hard enough. If I recall, Petro-Canada tended to publish the SA levels of their PCMOs, too.
