Originally Posted By: pbm
Originally Posted By: KenO
What else can this realistically be used in? It looks like VW Diesel only, but if you use the Lubrizo tool to compare the oil specs, it looks like an insanely robust oil, overall. Any thoughts? It's on clearance at Autozone now and I snagged a few dozen quarts, so I may as well figure out what its safe to use in - because god knows I'll never own any VW junk lol.
The bottles I saw at AZ were marked SN and were in dark gray containers (like the original PU).
I believe this is the PDS:
http://www.pennzoil.com/en_us/products/f...c_Motor_Oil.pdf
I would use that oil in any and all the cars in your signature that spec 5w30.
CORRECTION:
After rechecking the containers....they DO NOT show SN on them....the SN was in the PDS.....sorry for the misinformation.
The containers do say:
"Suitable for fuel injected gasoline and diesel engines fitted with 'blow by' recirculation and catalytic converters operating in extreme driving conditions"
ALSO
"Meets or exceeds the requirements of the following industry specifications: ACEA A3/B3/B4, ACEA C2 &C3, BMW LL-04, MB approval 229.51, VW 504 00/ 507 00, Chrysler MS-11106.
Again, sorry for the earlier misinformation.
