Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
92 registered members (Ag76, Armkb, anndel, ABomb369, 14Accent, -SyN-, 14 invisible), 1,801 guests, and 32 spiders.
Topics290,954
Posts4,853,165
Members66,062
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
Stripped oil pan drain hole #4273894
12/13/16 04:06 PM
12/13/16 04:06 PM
Milwaukee
Patrologia Offline OP
Milwaukee
The dealer tells me that the threads are partially stripped on the drain plug and hole, and that I should plan to replace my oil pan. They sealed it all up with Honda bond this time, but can't promise how many times that will work for me.
My question is this--wouldn't it make better sense to just tap new threads and use a larger size drain plug? Other than wanting to bring my in for a $700+ job (which isn't going to happen anyway; I only did the OC at the dealer because they offered a Mobil 1 oil change cheaper than I could buy the oil at WalMart), why would it be better to replace the pan?
IF I do need to or decide to replace the pan, should I just put the Honda part on? Is there a "better" oil pan out there?
(By the way, I didn't strip the bolt. I just bought the car at the end of the summer, and haven't even been under it yet.)
2009 Hyundai Santa Fe SE 3.3L
2003 Honda Civic EX
Re: Stripped oil pan drain hole [Re: Patrologia] #4273896
12/13/16 04:10 PM
12/13/16 04:10 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Steel or Aluminum pan?
Re: Stripped oil pan drain hole [Re: Patrologia] #4273899
12/13/16 04:11 PM
12/13/16 04:11 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Honda sells a repair kit and I'm sure there are aftermarket ones out there too. However, when I looked into it for a friend a while back the repair kit was about as expensive as a new pan so that's what we did.
If you can find an oversize plug then give it a try. You'll still need the correct drill and tap, and I'd take the pan off to do that work if it were me. When we evaluated all the options we just decided on a whole new pan.
I also saw some self-tapping plugs but I wasn't willing to try that on a friend's car. You might however.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: Stripped oil pan drain hole [Re: Patrologia] #4273900
12/13/16 04:13 PM
12/13/16 04:13 PM
Milwaukee, WI
bepperb Offline
bepperb  Offline
Milwaukee, WI
It's stamped sheet metal, there isn't going to be material to drill the hole larger and tap a larger hole. Besides, doing so should require you to pull the pan anyway (unless you want shavings floating around your oil), why would you not then use a new pan?
I'd rockauto a pan and a gasket, I'm sure it's a 30 minute job and probably fairly inexpensive.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
Re: Stripped oil pan drain hole [Re: Patrologia] #4273904
12/13/16 04:17 PM
12/13/16 04:17 PM
Idaho
sprite1741 Offline
sprite1741  Offline
Idaho
There are repair plugs and what not, but it's not worth the worry. Replace the pan, try a bone yard for a cheap one.
2005 Grand Prix GXP 5.3L Supertech Syn Dexos 5w30 Fram Ultra 3506
1986 Dodge Lancer 2.2L Turbo, Chevron Supreme 10w30 Fram Ultra 3614
Re: Stripped oil pan drain hole [Re: Patrologia] #4273911
12/13/16 04:26 PM
12/13/16 04:26 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Replace the pan. Obligatory Jiffy Lube reference.
Re: Stripped oil pan drain hole [Re: Patrologia] #4273912
12/13/16 04:27 PM
12/13/16 04:27 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Suggest bonding in an oil drain valve, using the same thread as original.
Oil Drain Valve
BTW, I have not used this product. There are also other similar products.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Stripped oil pan drain hole [Re: Patrologia] #4273919
12/13/16 04:40 PM
12/13/16 04:40 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
http://www.ebay.com/itm/Needa-Parts-652006-1-2-Rubber-Oil-Drain-Plug-/371528392978?hash=item5680d16112:g:8e0AAOSw65FXvdQy&vxp=mtr
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Stripped oil pan drain hole [Re: Patrologia] #4273925
12/13/16 04:49 PM
12/13/16 04:49 PM
JimPghPA Offline
JimPghPA  Offline
There are rubber drain plugs like:
and there are drain plug repair kits made specifically for Hondas such as:
http://cgi.ebay.com/ebaymotors/Time-Sert-1415C-M14x1-5-Metric-Drain-Plug-Repair-Kit-for-Honda-Acura-/282233113597?hash=item41b6678bfd:g:RC4AAOSwA3dYEA43
Look on ebay under rebber drain plug, and under Honda drain plug repair
JimPghPa
Re: Stripped oil pan drain hole [Re: Trav] #4273930
12/13/16 04:56 PM
12/13/16 04:56 PM
Milwaukee
Milwaukee
I don't know. They didn't say, and I haven't gone under the car to check (it's 13 F out today!).
I assume it is original, but I don't know what that was. It has the VTEC engine if that means anything.
2003 Honda Civic EX
Re: Stripped oil pan drain hole [Re: knerml] #4273935
12/13/16 05:01 PM
12/13/16 05:01 PM
Milwaukee
Milwaukee
Oil Drain Valve
That looks interesting, but I think I'd be afraid to trust it. Does it have a good rep?
2003 Honda Civic EX
Re: Stripped oil pan drain hole [Re: Patrologia] #4273944
12/13/16 05:08 PM
12/13/16 05:08 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I was a mechanic at a Honda dealer before more schooling to eventually become a UPS semi mechanic.
VTEC oil pans were aluminum while non VTEC were stamped steel. The problem was people would not use a new crush gasket for every oil change and damage the threads. Some people could get away with changing the oil 50 times without using a new crush gasket, but... .
Me: 13' VW GTI 3 door 6 speed manual
Re: Stripped oil pan drain hole [Re: Patrologia] #4273953
12/13/16 05:18 PM
12/13/16 05:18 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
The one I did was aluminum. His daughter (away at school) took it to Walmart for an oil change and they stripped it. She took it back and they sent it somewhere for a "repair" which consisted of installing a self-tapping plug. It still leaked. When she came home for the summer I put on the new pan for him.
BTW if it is aluminum and you do buy a new pan, the new one does not come with a nipple for the oil filter (assuming yours is like the one I did). You have to buy it separately.
1994 BMW 530i, 228K
Re: Stripped oil pan drain hole [Re: Patrologia] #4273960
12/13/16 05:26 PM
12/13/16 05:26 PM
England
UltrafanUK Offline
UltrafanUK  Offline
England
I would not do a drill and tap job, as you need a flange for the sump plug washer.
Although you could try the Honda repair kit (Not sure if it's just a helicoil insert and matching plug or not), the cheapest solution is to just seal the plug in and use an oil drain pump (The Pela is a good one), like the Iffylube places do.
You could also use a good sealant (Marine Silkoflex or one of the sealants used when installing a new HG will work) to install a Fumoto valve.
The only time the pan needs replacing is if it's been grounded or hit by a rock!
Shell Ultra 0 or 5w40 or Liqui Moly 5w40 plus Ceratec every long OCI.
LM idle flush every 100K km.
Re: Stripped oil pan drain hole [Re: Patrologia] #4273974
12/13/16 05:53 PM
12/13/16 05:53 PM
Trav Offline
Trav  Offline
IIRC some Honda aluminum pans used a short thread drain bolt but there are a lot of unused threads further in and a longer drain bolt will work and seal fine. I cant remember the model or the years.
You can check this by looking in the hole at the threads and measuring up there then measure the bolt length, if there are more threads then go and get a longer drain bolt with new washer and tighten it carefully. If somebody knows more about this please chime in.
Page 1 of 4 1 2 3 4
