Originally Posted By: clinebarger
Originally Posted By: DeepFriar
Aftr watching some 4L60E videos I had come to see the shell spline as a weak link, worst thing that might result from thee "clunk". It just looks weak the way it's welded to the shell. I would like to hear what a repair procedure would be. Not so I can do it, not able for a long list of reasons including not being an ace mechanic, but to recognize if it gets worse and also communicate better to a tech. If you would send me a PM or post that here I would appreciate it very much. Thanks. At least a common problem is one others have seen or are interested in knowing about.
Sure....
Loose 2/4 Band Clearance is a big contributor to this, GM/Hydramatic sets them loose from the factory for some unknown reason. With the Band loose the 2nd Servo Piston is allowed to pick-up to much speed & SLAM into the Band causing the "Bump" at the end of the shift.
Band Clearance can be corrected with a extra long Servo Apply Pin (Sonnax part# 77787-02K) It needs to be machined/ground to achieve .040"-.060" Clearance checked with a dial indicator at the Servo Cover.
You probably have .120"+ clearance now.
The "Soft Slide" at the beginning of the shift is caused by the 2nd Servo Piston being to small, Replace with a Corvette 2nd Servo.....
HERE
Install AcDelco Cushion Spring part# 8681195....
HERE Install WITH the original Cushion Spring!! It DOES NOT replace it!!
Install a new Sonnax .470 Boost Valve, This is a STOCK ratio boost valve, Not a high performance part! This will restore the hydraulic integrity & prevent "Torque Signal Oil" from leaking around around the sleeve &/or the boost valve itself....
HERE.
Install Sonnax Servo Release Check Valve....
HERE
This will help 3/4 Clutch life, Follow the directions for a Corvette Servo!!
Install a 2004 Corvette Separator Plate part# 24244053.....
HERE
It has the correct orifice sizes for the Corvette 2nd Servo. If you use your OE plate....2nd gear will hit harder than you want, This plate has a smaller 2nd Clutch feed Orifice!
While the Valve Body & Plate are out, Check the 2nd Accumulator Housing for broken Springs &/or a worn/broken Piston. I order what I need from the dealer by VIN, There are 2 different Housings that require different spring sets & pistons, Installing the wrong spring/piston combinations will break the springs in short order!
Red arrow is the 2nd Accumulator Housing, The Yellow arrow in the Servo Cover....Just to give some points of reference.
Wow, clinebarger, that is the most complete post I've ever seen! Many, many thanks for taking the time to do that. With this widespread of an issue I think your post should qualify as a sticky both for the list and for the spiders to find. I hope Wayne will agree. Final questions - how bad does it have to get before you dive in because I would think a shell spline failure would immediately be cause for total replacement? Does a preemptive approach make more sense for a non-mechanic? And finally, considering labor, fix it or go reman and be done with it? Where do I send your doughnuts? Thanks again.
