2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
Comma X-Tech 5w30 oil, any good?
by BobGoblin. 12/17/18 11:40 AM
Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
107 registered members (77GrandPrix, Asterix, AdditiveOCD, 69Torino, aquariuscsm, Anduril, 9 invisible), 2,104 guests, and 47 spiders.
Topics295,184
Posts4,929,391
Members66,700
Most Online2,553
Oct 27th, 2018
Amsoil bmk23 #4238607
11/01/16 12:04 AM
11/01/16 12:04 AM
Virginia, usa
Shata Offline OP
Shata  Offline OP
Virginia, usa
Is there issue using fram xg8a for full flow on these kits?
16 Silverado 2500 6.6 Dmax
15w-40 Mobil Delvac
Fram Ultra XG9100
Filter Mags: Fuel filter, Allison and engine.
Re: Amsoil bmk23 [Re: Shata] #4238832
11/01/16 08:48 AM
11/01/16 08:48 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Not at all. But why run a bypass?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Amsoil bmk23 [Re: Shata] #4238843
11/01/16 08:56 AM
11/01/16 08:56 AM
Texas
mpersell Offline
mpersell  Offline
Texas
For me the bypass is just extra safety margin. UOA's have shown no ill effects and good positive attributes.
2016 Kia Soul - Amsoil
2017 Tundra - Amsoil
Making a living with free software
Re: Amsoil bmk23 [Re: Shata] #4239332
11/01/16 07:50 PM
11/01/16 07:50 PM
Virginia, usa
Shata Offline OP
Shata  Offline OP
Virginia, usa
You'd have to do some research online I don't remember what article is called but gm a few years back wrote paper saying essentially all engine wear is mostly produced between particles in size range of the 2-20 micron. With bypass systems not only do you get moisture removal but also perfect clean oil down to 2 micron and their able to cycle about 8-10 quarts in 10min of driving. Meaning clean oil and oil intervals with gasoline engines in the 20-30k miles depending on UOA results. I'm not doing It for extended intervals but for clean oil and less wear. There was one article I saw with chevy 454 that had bypass system since new with 500k miles disassembled with no copper showing in bearing wear. There is reason fleets and heavy diesel use these they work excellent.
Reason I posted this thread is my main concern was amount of restriction the full flow EAO filter has vs this fram xg8a which could effect flow to the bypass maybe? The xg8a is equivalent filter to what is used by amsoil in the full flow spot. Am I maybe over thinking this?
15w-40 Mobil Delvac
Fram Ultra XG9100
Re: Amsoil bmk23 [Re: Shata] #4239633
11/02/16 07:46 AM
11/02/16 07:46 AM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
Shata,
Fear not my friend. Every full flow filter on the market flows enough to feed the engine with a safety factor built in. Run the full flow filter of your choice along with your bypass. Try googling "engine blown due to bypass oil filter." You'll come up with nada.
I have previously run an Amsoil bypass, Kleen-Oil, NTZ, Puradyn, etc. The size of the feed line to the bypass IS the restriction feeding the bypass, and some manufacturers have smaller input orifices than the 1/8" ID feed line they recommend.
Have fun.
2003 Lesabre Celebration Edition
2004 Lesabre
2004 Lesabre Celebration Edition
Re: Amsoil bmk23 [Re: Shata] #4240289
11/02/16 08:31 PM
11/02/16 08:31 PM
Virginia, usa
Shata Offline OP
Shata  Offline OP
Virginia, usa
Thanks appreciate the reply, I was assuming it wouldn't effect changing the brand of full flow. Just wanted to make sure. I like being able get my full flows locally and I'll order my bypass online obviously.
15w-40 Mobil Delvac
Fram Ultra XG9100
Re: Amsoil bmk23 [Re: Shata] #4241918
11/05/16 01:12 AM
11/05/16 01:12 AM
Virginia, usa
Shata Offline OP
Shata  Offline OP
Virginia, usa
So just for sh*ts and giggles I emailed amsoil about this and they said the following:
"I do not recommend using the FRAM XG8A on the AMSOIL Dual Remote Bypass System (Product Code BMK23). Although it appears that this filter will spin on to the system, we do not have information supporting the use of this filter or any other competitors filter. Due to the calibration of these systems, the AMSOIL EAO26 filter is recommended to ensure proper flow rates."
Your guys thoughts?
15w-40 Mobil Delvac
Fram Ultra XG9100
Re: Amsoil bmk23 [Re: Shata] #4573440
11/14/17 04:55 AM
11/14/17 04:55 AM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
Originally Posted By: Shata
Your guys thoughts?
They want you to buy THEIR filter because theirs is special.... LOL
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: Amsoil bmk23 [Re: Shata] #4573450
11/14/17 05:23 AM
11/14/17 05:23 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
No it's about them redirecting some oil flow to the bypass filter and the rest through a regular filter. If that regular filter offers too much restriction over the Amsoil one then the engine could starve for oil because some oil was already siphoned off for the bypass filter.
They are telling you that their system has been designed with their filters flow rates in mind because this is data they have and what they set the system up for to safely operate without engine damage. They don't have data and can't stand behind other filter manufacturers.
Amsoil EAO filters are designed to flow more oil and last a long time to go hand in hand with their 25,000 mile OCI guarantee.
You can't expect them to answer any other way because they don't own "X" filter company.
If someone did screw on a Fram and something happened as a result how could they stand behind their product and pay out the warranty claim?
Further if you are doing bypass you will be saving enough on regular changes that are no longer needed that you can afford their filters and still be ahead financially and if you can't then you shouldn't be doing bypass in the first place.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
