TriboChemistry IV - New HI VI Base Oil
MolaKule
Staff member
Iowegia - USA
This question has a three-part answer:
This new synthetic base oil, when blended-in with lower viscosity base oils, can provide a 5W30 engine oil formulation with an HTHS of 3.4@150C.
This fluid has a VI of 190, an EHL film thickness of 240 nm@[email protected] GPa, and a Pour Point of -33C.
1. What is the specific base oil type?
2. What is the viscosity at 40C?
3. What is the Commercial name of this product?
Here is hint:
This base oil is derived using a metallocene catalyst.
Originally Posted By: Ohle_Manezzini
Synthetic.
MPao.
Visc @ 40C about 68 Cst.
Joe Gibbs Driven Js30?
You have two out of three correct so far.
It is a Group IV.
Ohle, from the "Land of the Palms" was closer to the answer.
It is SpectraSyn Elite™ 300:
303cSt@100C 3358cst@40C -27F PP and 547F FP.
One application is its use (in small percentages) to formulate a low viscosity lubricant to provide increased hydrodynamic films at elevated operating temperatures.
Maybe it Should be added a little, to make a 5w30... Piston cup pin for me, please.
It's Pindah Palm's Land, Mola.
Due to the cost of the Piston Cup Pin and the state of the economy, we cannot, at this time, offer the Piston Cup Pin but will monitor the economy and if things improve, once again offer this coveted treasure.
older but good!! always learning from the Pros, thanks Mola for all of your interesting info!!
