flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
83 registered (4WD, 69Torino, Ag76, 87sammy, 2004tdigls, 2strokeNorthstar, 9 invisible), 1531 Guests and 37 Spiders online.
65265 Members
67 Forums
285548 Topics
Page 1 of 3 1 2 3 >
#4225380 - 10/14/16 01:21 PM Trying ATF in Harley primary
MoreCowbellAz Offline
Loc: Phoenix, Az
As I do maintenance on my '00 RK I like to experiment to see what works or doesn't work, and maybe other folks can benefit. Although I definitely follow the mfr recommendations as a starting point, I do admit I'm more willing than most to experiment a little, and with all the wildly varying opinions of the internet I like to see for myself. I'm not trying to outsmart the engineers, but I do recognize that the mfr's interests are not always aligned with the user's interests (to put it kindly).
Anyhow, I was due for a primary oil change, I had Valvoline Premium Blue 15w40 in there and it felt fine for the most part but after researching ATF in the primary I decided to give it a whirl. Lots of folks say ATF was like a night and day improvement in shifting and finding neutral, I was skeptical about that mainly because my bike already does that great, not sure how much better it could get but what the heck, let's see.
I installed Valvoline Dex/Merc ATF, and although I don't have a lot of miles on it yet it feels about the same as before with shifting and finding neutral, which is to say pretty darn good. I was happy before, I'm happy now. Where I did notice an improvement was in the clutch action, with both Rotella and Valv Prem Blue I'd feel some minor coarseness right in the engagement zone, and with the ATF it was smooth all the way through. I don't know if it's the additives or the lower viscosity, but it's definitely smooth as silk (not that it was a problem before).
I didn't notice any increase in primary chain noise, or any other problems. I have no way of knowing if it runs hotter or not. I'm going to run it 4-5k and see what the fluid and magnetic drain plug looks like. With the HDEO in there my drain plug had very little debris and the oil was pretty clean looking, so that's a decent baseline I think. At this point I think I could go either way with the ATF vs something like an HDEO oil from a feel perspective although the ATF for sure is a bit better.
Anyway, maybe this helps some of you experimenters. One thing I'll say is if your bike is banging into gear or you can't ever find neutral you have a clutch adjustment problem more than a primary oil problem. But I do love me some Redline SPH in the tranny.
07 Toyota RAV4 2.4L
07 Toyota Prius Touring
00 Harley Road King Classic
11 Kia Soul 2.0L (mine to maintain)
#4225428 - 10/14/16 02:36 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
MotoTribologist Online   confused
Loc: NJ, USA
Any thinner oil should be an improvement over the Primary+ or whatever 20W-50 HD puts in there nowadays. Those primaries excel with an SAE 30 or equivalent trans oil. I'm not surprised ATF feels good in comparison. Report back on the drain plug and fluid results at the end of your 5K. I'd be interested to hear if the ATF protects as well as some other fluids.
#4225505 - 10/14/16 04:33 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Blkstanger Offline
Loc: Lakeside, CA
I did the same thing some years ago. It ended up working out great for me. Gone are the days of starting a cold bike and having it clunk into gear. I will never use anything else in a Harley primary. Much better clutch feel too. I think it was about 2006 when I started doing this. I must have 85-90k miles on two different bikes using ATF.
99 Jeep WJ 4.7 185,000 Maxlife 10w30, Fram Ultra.
#4225567 - 10/14/16 05:52 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
GMBoy Offline
Loc: Texas
You'll notice more improvements with the transmission fluid change than the primary fluid. The primary fluid doesn't lubricate your gears and you can almost run anything in the primary and not know the difference.
#4225606 - 10/14/16 06:48 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Loc: Phoenix, Az
I'll definitely report back at 5k. Short of there bunch of debris on the plug magnet or loads of clutch material in the drain I'm not sure I see the downside from using ATF, given the noticeably smoother clutch action. I'm sure I would be happy continuing with the HDEO, but more smoother is more better right?
As I said before, I don't see nor did I expect to see any improvement in shifting since my bike already shifted great, so I agree that the tranny fluid has more bearing there. But I'm loving the extra smoothness the ATF provides as you feather out the clutch when in gear.
Also, I'm no engineer but logic would make me guess there's nothing going on in a Harley primary in the way of plates, bearings, gears, etc. that you don't see in cars/trucks that use ATF for many times the OCI a Harley would see. I could be wrong there, but it seems the fluid would be up to the task in Harley primary if it can go 50k in an offroad 4x4 or street rod.
I will gladly eat my words if I get stranded with a toasted compensator or exploded clutch plates. But I'm betting not.
07 Toyota RAV4 2.4L
#4225725 - 10/14/16 10:01 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Blkstanger Offline
Loc: Lakeside, CA
You won't have any problems. I have torn apart my primary many times. Everything looked great.
#4225787 - 10/15/16 12:35 AM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
userfriendly Offline
Loc: LaFinDuMonde
I'm switching my light truck transfer case fluids from ATF to THF. These fluids may work in your application.
www.chevronlubricants.com >>products>>industrial and off-road transmission fluids>> 1000 thf & synthetic all-weather thf
1000 THF
40C 58.4
100C 9.5
VI 145
flash 235C
pour -42C
SYN THF
40C 44.7
100C 9.5
VI 204
flash 242C
pour -45C
Edited by userfriendly (10/15/16 12:37 AM)
#4225952 - 10/15/16 09:07 AM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Loc: Phoenix, Az
I don't know the chemistry, but viscosity wise it looks like a slightly heavier version of ATF, like a 30. I know the Valvoline Dex/Merc I put in is a 20. First time I've heard someone mention THF, interesting.
07 Toyota RAV4 2.4L
#4226138 - 10/15/16 03:11 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Robenstein Offline
Loc: Central IA
You could pop in Type F, which tends to be a bit thicker than the Dex/Merc ATF's if I recall.
Edited by Robenstein (10/15/16 03:13 PM)
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#4226161 - 10/15/16 04:07 PM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Loc: LaFinDuMonde
THF can also be used as a hydraulic fluid and therefore compatible with fork and shock seals, if the ISO grade is close to your needs.
#4226442 - 10/15/16 11:20 PM Re: Trying ATF in Harley primary [Re: Robenstein]
Blkstanger Offline
Loc: Lakeside, CA
I have tried the type F and it made the clutch grab a little quicker. I liked it.
#4226995 - 10/16/16 06:07 PM Re: Trying ATF in Harley primary [Re: Blkstanger]
Robenstein Offline
Loc: Central IA
Old timer drag racers noticed this too and you would see them putting type F in GM autos for firmer shifts at the drag track.
1970 Chevy Nova
2006 Scion TC
#4227034 - 10/16/16 06:48 PM Re: Trying ATF in Harley primary [Re: GMBoy]
Gillsy Offline
Loc: Owego, New York
My experience showed me the opposite. I tried 20w50 Mobil 1, Spectro Platinum 6 speed, and Mobil 1 gear lube in the transmission. There was no difference perceived between the three. I used Rotella T, Mobil 1 20w50, and type F transmission fluid in the primary. I didn't like any of them. I put Spectro Platinum Primary Chaincase fluid in and winner, winner, winner. Smooth shifts, and super easy into neutral every time.
Many are the afflictions of a righteous man
2018 F150 Supercab 2.7 Ecoboost 4x4
400 lbs/ft of grin at 2750 RPM
2016 Kawasaki 650 Versys LT
#4228181 - 10/18/16 08:18 AM Re: Trying ATF in Harley primary [Re: Robenstein]
JetStar Offline
Loc: Flatlands of Indiana
I remember those days, I used to bowl with the transmission shop guys next to where I worked at the time. They told me B&M trick shift was just blue dyed, type F. I tried the type F and it did make a difference in my TH350.
My weakness is I love all motorcycles regardless of brand
2017 Wide Glide
2016 Suzuki DR650
2015 Road Glide
2007 Yamaha FZ1
1978 Suzuki GS1000 (now 1085)
#4228280 - 10/18/16 10:25 AM Re: Trying ATF in Harley primary [Re: MoreCowbellAz]
Silverado12 Offline
Loc: Central Virginia
FYIFWIW I read somewhere that on the newer 2007 up Harleys you're supposed to run 40 oz. in the primary to properly lube the weak compensator.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
16 Challenger R/T Shaker 5.7 manual B5 blue
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Page 1 of 3 1 2 3 >
