So after reading about the grab bag of possibilities from the discount filters available from Rock Auto, some friends and I took a chance and ordered a TON of filters. Some of those filters are the common Toyota size filters equivalent to a Fram PH3614 or Purolator L10241. When the filters arrived they very closely resemble some of the details of a OEM Toyota filter, such as the O-ring style gasket, black can complete with old Toyota numbering system and also the cellophane that seals the filter in the box. A feature that is on OEM Toyota filters as well as other filters such as the Beck Arnley which I also have a few of here at the house. Other filters purchased were almost exclusively Carquest Red and Blue filters, all filters were $1.41 or $1.42 each, I will detail what I purchased in another thread. So without further delay here are the pictures.
Initial Cut
ADBV on initial cut
ADBV
Filter media and glue drip/run
Wide pleat spacing on aprox 1/8 of the total media
Drip close up
Bottom End Cap Bypass valve
Inside metal seam
Filter media
Inside Can with spring
Spring
Perf Tube
Continued on next post...
Initial Cut
ADBV on initial cut
ADBV
Drip close up
Inside metal seam
Filter media
Spring
Perf Tube
