4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
67 registered members (97prizm, ad_infinitum, 4WD, 2010Civic, Agnosto, 5 invisible), 1,372 guests, and 66 spiders.
Topics286,042
Posts4,901,391
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Rock Auto UltraPower Toyota filter copy? Cut open! #4165715
07/31/16 06:48 PM
07/31/16 06:48 PM
Jacksonville, FL
FlyNavyP3 Offline OP
Jacksonville, FL
So after reading about the grab bag of possibilities from the discount filters available from Rock Auto, some friends and I took a chance and ordered a TON of filters. Some of those filters are the common Toyota size filters equivalent to a Fram PH3614 or Purolator L10241. When the filters arrived they very closely resemble some of the details of a OEM Toyota filter, such as the O-ring style gasket, black can complete with old Toyota numbering system and also the cellophane that seals the filter in the box. A feature that is on OEM Toyota filters as well as other filters such as the Beck Arnley which I also have a few of here at the house. Other filters purchased were almost exclusively Carquest Red and Blue filters, all filters were $1.41 or $1.42 each, I will detail what I purchased in another thread. So without further delay here are the pictures.
Initial Cut
ADBV on initial cut
ADBV
Filter media and glue drip/run
Wide pleat spacing on aprox 1/8 of the total media
Drip close up
Bottom End Cap Bypass valve
Inside metal seam
Filter media
Inside Can with spring
Spring
Perf Tube
Continued on next post...
Luke
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165724
07/31/16 06:56 PM
07/31/16 06:56 PM
Jacksonville, FL
Jacksonville, FL
Perf Tube 2
Perf Tube 3
Top end cap
Bottom end cap with bypass valve
Filter threaded plate, holes around adbv are slightly sharp, yard to say if they would cut the adbv or not over time
45 Total pleats, 53.5"x2.5" Total media Area 133.75 in sq
Overall I really can't complain for a $1.42 filter. I bought a few so we'll see how they do in service, thoughts and comments are always welcome.
Luke
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165727
07/31/16 07:12 PM
07/31/16 07:12 PM
Denver
marine65 Offline
marine65  Offline
Denver
Why in the world would you put a $1.42 unknown filter on your engine?
For $5 or $6 more you can get a filter of known quality.
I just don't get it.
2018 Hyundai Elantra GT
yup got two of them.
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165731
07/31/16 07:21 PM
07/31/16 07:21 PM
California
Kool1 Offline
Kool1  Offline
California
Thanks for posting the pictures. I see the Japanese words on the filter; does it say on the oil filter or box where the filter is made?
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: marine65] #4165749
07/31/16 07:46 PM
07/31/16 07:46 PM
Jacksonville, FL
Jacksonville, FL
I knew I'd get some blow back on this, however lots of people drive lots and lots of miles every day on e-core filters, Fram with paper end caps, God knows what filters the oil change places use...
So I want to examine your statement for a moment. I bought a few filters, cut one open to examine it. Metal end caps, reasonable media pleat spacing, appears to be well constructed. It's at least as good as many of the other filters that I've used in the past.
As for price, I'm not sure what that has to do with anything. I also purchased a dozen oil filters that fit the newer Ford's or oil cooler pushrod V-8's they were all Car Quest Red filters made by wix, $1.41 ea. Standard Ford V-8 filters (1515 PH-8A etc) also for $1.41 ea they were half and half Wix Car Quest red purchased as wholesaler close out wix and the other half were marketed as Ultra Power and they were Car Quest Blue. Plus some equipment filters, all CQ Blue. All of those were bought for $1.41/1.42 each.
The only filters that weren't Wix were these Toyota filters, at the end of the day after cutting one I'm comfortable using them. I could change it every 1,000 miles and still be money ahead over boutique fancy filters on a 3,000-5,000 mile oci. After buying nearly 50 Carquest red and blue Wix filters for the price I did, I'd say I did alright overall.
Luke
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165751
07/31/16 07:48 PM
07/31/16 07:48 PM
CZ factory 🏭 KC KS
Marco620 Offline
Marco620  Offline
CZ factory 🏭 KC KS
I used proselect from napa on my hyundai with synthetic oil but never pushed them past 4100 miles. I would keep an eye on these.For the price you can afford to change them more often and I probably would.
15' Civic 1.8 i-vtec 221,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: Kool1] #4165753
07/31/16 07:48 PM
07/31/16 07:48 PM
Jacksonville, FL
Jacksonville, FL
I can't find any indication of where it's made. The Beck Arnley filters that I have with the same cellophane sealing plastic are made in Korea, genuine Toyota filters of this size are made in Taiwan to the best of my knowledge. For all I know it's a knock off made in China, but upon dissection I'm comfortable using it.
Luke
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165799
07/31/16 08:47 PM
07/31/16 08:47 PM
New Jersey
crazyoildude Offline
New Jersey
looks like a cheap filter for sure looks like the media is made from old shopping bags and then add some louvers and who knows what can happen WOW
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165801
07/31/16 08:51 PM
07/31/16 08:51 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Haha I got a couple of those same filters as well. Thanks for cutting one open.
I am guessing it was a fake filter that got pulled from the Denso box and reboxed after it was found out. That's how it ended up as is.
yup
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: crazyoildude] #4165804
07/31/16 08:55 PM
07/31/16 08:55 PM
Lake Forest, CA
HTSS_TR Offline
HTSS_TR  Offline
Lake Forest, CA
The media isn't that bad, it is about the same quality of Purolator Classic and Fram Extra Guard, but I may not use this filter in my car(s) for more than 5-6k miles.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: Jimzz] #4165810
07/31/16 09:05 PM
07/31/16 09:05 PM
Jacksonville, FL
Jacksonville, FL
That's a great theory. I bet you're right. To me they looked like a Chinese copy of an OEM Toyota filter. For my 3,000-5,000 oci with conventional in my 315,000 mile 4Runner I bet they'll be just fine. I will post up pictures of one after it's been used.
Luke
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: HTSS_TR] #4165811
07/31/16 09:07 PM
07/31/16 09:07 PM
Jacksonville, FL
Jacksonville, FL
It didn't look terrible to me either, very obviously not an ultra premium filter. But I didn't expect it to be. I took a chance on some grab bag filters and I'd say I 80% won considering that's about how many were CarQuest red or blue. These I will still run, they'll do for what I need. Glad to share with the BITOG community.
Luke
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165825
07/31/16 09:31 PM
07/31/16 09:31 PM
Huntington Beach, CA
tenderloin Offline
tenderloin  Offline
Possible MFG?
Scroll down for oil filters...
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: FlyNavyP3] #4165845
07/31/16 10:05 PM
07/31/16 10:05 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
They look like Union Sangyo made in Malaysia filters sold under the Nippon and some other names to me. I bought some about ten years ago. They were a version with red adbv. The lack of name, old factory part numbers and instructions are very similar, as well as the thicker than USA made can seam. It was for a Maxima and they caused start up rattle. I think due to being very old. If it is Union it should be a very good filter I would say. Someone whoever it was had the machinery means to make a good looking louvered center tube.
Re: Rock Auto UltraPower Toyota filter copy? Cut open! [Re: marine65] #4165870
07/31/16 10:51 PM
07/31/16 10:51 PM
VA
bvance554 Offline
bvance554  Offline
VA
Because the filter that costs $1.42 is just as good as the one you'd pay $5 or $6 for. I don't get that.
Page 1 of 4 1 2 3 4
