JHogan,
Thanks for sharing your insights as to what happens inside Audi.
Whatever the root causes of this issue, I reckon the problem must be rather complicated. I find it hard to comprehend how the Audi engineers and designers could get this engine so wrong and all I can think of is that several individual things coincided to create one huge, intractable problem.
From what I've seen, there are two distinct phases to the problem. From new, these engines used a higher than usual amount of oil. In this phase, you see oil moving out of the crankcase, through the PCV and into the intake system. There, over time, it would cause very bad inlet value deposits. Ultimately most of the oil gets burnt in the cylinder. Unlike gasoline, engine oil is very difficult to burn. Some of the deposits from partially burnt oil goes out with exhaust but equally some stays in the cylinder, on the top of the piston and down past the piston.
The second phase kicks in at around 50,000-ish miles when oil consumption, which was already high, goes completely off the scale. I suspect this the point at which the oil rings be either stuck solid or break. These are the engines Audi are still fixing.
