These videos show how to change headlight bulbs in a Volvo 2008 S60. My daughter 2006 V70 has similar setup. There isn't room to reach the bulb without removing the air box in driver side, and remove the ECU case on passenger side. I need to change the low beam bulbs often, because they use low beam as DRL at full power.
Changing light bulbs in the 2000 E430 is very easy, no need to remove anything. Changing both low beam bulbs(passenger and driver) in the E430 took me less than 3-5 minutes.
Passenger side
Driver side
Many things under Volvo hood are so unorganized, they look like just randomly placed. No wonder they are sold to Chinese.
Passenger side
Driver side
