Originally Posted By: Brybo86
Can you leave the battery on an automatic charger overnight? If it starts great after that then you know the battery is losing its gusto. Hopefully it is one with a 2 year free replacement.
This doesn't tell you if you have a parasitic drain as mentioned above. I'd put an amp meter in series with the negative terminal and see how many amps it is drawing before I went and bought a new battery. If its drawing over much over .05 amps you have a drain somewhere.
