Originally Posted By: Jetronic
But what if you're in a zero, and the other guy in an F-14. Would you try to vary your speed and manoeuvre in such a way that the f-14 can't keep you in his gun sights? Low altitude as well I suppose. I imagine from seeing the above scene that's about the only advantage you would have...
A target that is rapidly changing direction, via roll, bank, and G, will be hard to hit. A hard pull orthogonal to the attacking fighter's line of sight will almost always break a gun tracking solution.
The challenge for the defending fighter (zero) is to maintain decent energy (altitude and speed) to be able to maneuver. Remember that gun engagements, with modern guns, take place at ranges from about 3,000 feet to 1,000 feet. There is some bullet time of flight, but mostly it's about screwing up the lead in the plane (geometric) that the attacking fighter has pulled to line up the shot.
F-14 v. Zero is nothing like Mustang v. ME-262 or P-40 v. Zero. The F-14 has a huge energy and speed advantage, not the advantage that was used back then, but a huge advantage.
With the understanding that asking fighter tactics questions is a bit like asking, "what's the best chess move?", because the answer is both complex and dependent on the situation, the best way to press the F-14 advantage v. A small prop plane is to stay well above, and get a weapon solution (heat and/or radar) and fire from the sanctuary of much higher altitude.
The Zero hopes that the F-14 will come down to his altitude, where the zero can get guns on target. This actually is depicted in the movie scene. But if the F-14 is smart, then he never gets down to where the Zero can get a shot. This makes a pure vertical gun shot a bit risky, as the F-14 has to fire, and turn to get out of range before the Zero,can point his nose at the attacking F-14.
The Zero's turn radius is tight, both in the horizontal, and vertical. But in the vertical, the Zero can only point up at the attacking F-14 for a moment, then it has to finish the vertical maneuver and regain lost energy. He has to finish the loop. The F-14 can time the attack, and shot, to avoid the Zero ever getting nose on...
Now, up at high altitude, for a Zero, the weapon lock will be much easier (discrimination is easier as the background isn't the sea), so lock him and shoot him with a missile. However, the same energy advantage exists, so the same gun tactic can be used, if one was low on missiles...
