I've been using Amsoil EAO filters in this vehicle because they have a synthetic element. However, Amsoil has not been consistent about which filter they recommend for this vehicle.
They were recommending the EAO37 which cross-references to the WIX 51393. Then they switched to the EAO34 which cross-references to the WIX 51516. They switched back to the EAO37, but now that filter is no longer available. The recommended MANN filter is the W 719/30.
The WIX 51393 is similar in specification to the MANN W 719/30. However, the WIX 51516 has a lower bypass pressure of 8-11 psi instead of 30 psi for the WIX 51393. The MANN filter has a bypass pressure of 2.5 bar, which converts to 36 psi. Also, the gasket for the WIX 51516 is not the same size as the gaskets for the WIX 51393 and the MANN W 719/30. Based on the lower bypass pressure and the different gasket size, I question whether the EAO34 / WIX 51516 is the correct filter for this vehicle.
I'm looking for an alternative filter with a synthetic element. The only one I found is the Bosch L3421. Are there any other alternatives?
