2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
67 registered members (Astro14, ABomb369, advocate, 2013ecof150, 1JCB, askani79705, 4 invisible), 1,224 guests, and 37 spiders.
Topics290,627
Posts4,847,665
Members66,011
Most Online3,590
Jan 24th, 2017
Wix's custom filter 57002 created for Mazda... #3446537
08/05/14 10:12 AM
08/05/14 10:12 AM
KC
badtlc Offline OP
badtlc  Offline OP
KC
I finally got tired of trying to figure out what was special about Wix's new 57002 filter specfic for only Mazda Skyactiv engines. I know it doesn't have an ADBV and has a 15 micron rating, but that doesn't tell me much. There has to be something special in order for Wix to go and create a new filter while everyone else didn't.
I emailed Wix Tech Support and asked for information. I'll post anything I get back in this thread.
2007 Ford Escape XLS 2.3L ATX, M1 AFE 0W20, Fram TG, 165k+
2015 Chrysler T&C, 75k+, M1 AFE 0W20, Fram TG OF
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3446542
08/05/14 10:14 AM
08/05/14 10:14 AM
MEMPHIS, TN
CHARLIEBRONSON21 Offline
MEMPHIS, TN
Someone told me it was a different bypass pressure. Not sure if that was true.
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3446555
08/05/14 10:22 AM
08/05/14 10:22 AM
Florida
ElastoHydro Offline
ElastoHydro  Offline
Florida
Originally Posted By: badtlc
.... I know it doesn't have an ADBV and has a 15 micron rating, but that doesn't tell me much. ...
What does 15 micron rating mean? Are you talking its 50% @ 15 microns using ISO 4548-12 test procedure? Or 'absolute' which might mean its 99% @ 15 microns???
http://www.lenntech.com/library/fine/absolute/absolute-nominal-filters.htm
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3446561
08/05/14 10:23 AM
08/05/14 10:23 AM
Florida
ElastoHydro Offline
ElastoHydro  Offline
Florida
Wix's regular oil filters are typically 95% @ 20 microns, unless Mazda specified they want better media.
Re: Wix's custom filter 57002 created for Mazda... [Re: ElastoHydro] #3446596
08/05/14 10:49 AM
08/05/14 10:49 AM
KC
badtlc Offline OP
badtlc  Offline OP
KC
I wish I knew. Wix and Oreilly's site just say "rating: 15 micron"
Re: Wix's custom filter 57002 created for Mazda... [Re: ElastoHydro] #3446599
08/05/14 10:49 AM
08/05/14 10:49 AM
KC
badtlc Offline OP
badtlc  Offline OP
KC
This is why I asked. I'd really like to know if Mazda spec'd out something super high. And it is impossible to get specs on OEM filters.
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3446611
08/05/14 11:06 AM
08/05/14 11:06 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Can't Wix test an OEM Mazda filter and reverse engineer it ?
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3446615
08/05/14 11:07 AM
08/05/14 11:07 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
from wix: No Beta just nominal rating.
Part Number: 57002
UPC Number: 765809570023
Principle Application: Various Mazda (13-15)
Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.827
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed:
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 11-14
Nominal Micron Rating: 15
Gasket Diameters
Number
O.D.
I.D.
Thk.
Attached 2.464 2.257 0.2
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3447844
08/06/14 12:21 PM
08/06/14 12:21 PM
KC
badtlc Offline OP
badtlc  Offline OP
KC
OK, I just got off the phone with a Wix person, not in engineering frown and this was what I learned:
With regards to the 57002:
- Wix can only publicly say the threads are different for the 57002 filter.
- No comment on what "nominal 15 micron rating" mean. Not quantification of percentage or anything. No beta ratios will be published.
- Wix took the OEM filter, tested it, and made a filter that was AT LEAST equal to the OEM in every way, including filtration efficiency.
I will start another thread about some other information I learned.
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3447847
08/06/14 12:26 PM
08/06/14 12:26 PM
Florida
ElastoHydro Offline
ElastoHydro  Offline
Florida
^^^^^ "Nominal" here may mean its 50% @ 15 microns, not sure. Sometimes its customary to state the half (50%) point as nominal.
If true, that means this filter uses the same media regular Wix and NAPA Gold filters use in all likelihood, since regular media is good to 95% @ 20 microns using ISO 4548-12.
Re: Wix's custom filter 57002 created for Mazda... [Re: ElastoHydro] #3447852
08/06/14 12:31 PM
08/06/14 12:31 PM
KC
badtlc Offline OP
badtlc  Offline OP
KC
The guy said he could not quantify the rating in any way due to disclosure restrictions. I asked if that was what it meant.
They list beta ratios for several other Wix filters and they are NOT the same. There seems to be no standard Wix filter media.
Re: Wix's custom filter 57002 created for Mazda... [Re: ElastoHydro] #3447855
08/06/14 12:34 PM
08/06/14 12:34 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
That would be my take too.
Re: Wix's custom filter 57002 created for Mazda... [Re: ZeeOSix] #3447863
08/06/14 12:39 PM
08/06/14 12:39 PM
KC
badtlc Offline OP
badtlc  Offline OP
KC
problem is there is no regular media for Wix & Napa Golds.
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3447868
08/06/14 12:44 PM
08/06/14 12:44 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
"Disclosure restrictions" ...? Wow, is it some super secret or maybe it's too bad to show the consumer?
Re: Wix's custom filter 57002 created for Mazda... [Re: badtlc] #3447919
08/06/14 01:48 PM
08/06/14 01:48 PM
Florida
ElastoHydro Offline
ElastoHydro  Offline
Florida
Very often we see beta ratios of 2/20=6/20, which translates to 50%@6 microns & 95%@20, which indicates they use the same filter paper/glass blend in Wix and NAPA Gold. Are there some exceptions? Probably.
