2014 GMC Sierra 7200 Miles Cam2 Semi Syn 5/30
by Audios
12/06/16 03:44 PM
What's up with all of the thread police?
by grampi
12/06/16 03:14 PM
calling on the experts. diesel oils in bikes??
by 675luke
12/06/16 02:36 PM
Glycol Tester
by benjamming
12/06/16 01:46 PM
Holiday luncheon @ work.
by montero1
12/06/16 01:30 PM
Magnefine Transmission Filter
by charmer37
12/06/16 01:09 PM
Wards article on CVT's
by supton
12/06/16 12:48 PM
USPS stinks
by pbm
12/06/16 09:26 AM
Super S oil on sale
by barkingspider
12/06/16 08:44 AM
Wind Tree
by AirgunSavant
12/06/16 07:53 AM
Schaffers 9000 5W-30 or Amsoil Sig. series 5W-30
by Ian1982
12/06/16 07:51 AM
Go high mileage or just thicker viscosity?
by skaughtz
12/06/16 07:23 AM
Kettle, andrewnathaniel, INTLDNA4900MIKE, rednari, swine
59801 Registered Users
104 registered (69GTX, Al, 675luke, 38Chevy454, 4WD, 2002 Maxima SE, 8 invisible), 2030 Guests and 19 Spiders online.
59801 Members
66 Forums
257940 Topics
Page 1 of 2 1 2 >
#3444478 - 08/03/14 07:53 AM Leaking AC compressor life....
gregk24 Offline
Loc: FL, USA
The AC compressor on the Accord in my sig is leaking oil/freon. I noticed this the other day when I was underneath the car and saw oil on the oil pan, then realized it was flinging off of the AC compressor. I took it in the my mechanic to get their opinion on where the oil was coming from and they did confirm it was leaking from the compressor, he said that it will need a new one but just to run this one until it stops working. As of now the air still blows cold. Has anyone had a leaking compressor before, and if so about how long should I expect this one to last? I will need to save up to get this fixed. Not even sure how much it will be but I know its pricey. Thanks!
2012 Honda Accord EX-L
Taffeta White - Ivory
42,xxx miles
PPPP 0w20 / Fram Ultra
#3444487 - 08/03/14 08:01 AM Re: Leaking AC compressor life.... [Re: gregk24]
3800Series Offline
Loc: Gulf Coast, MS
My old Volvo leaked. I think it would leak out in about 2 weeks. As for killing it even after 4 years it didn't die. To be honest tho I stopped putting freon in it long before that.
#3444488 - 08/03/14 08:02 AM Re: Leaking AC compressor life.... [Re: gregk24]
Charlie1935 Offline
Loc: DuQuoin, Illinois
Some where between 5 minutes and 5 years is my guess.
Seriously, no telling.
Probably be cheaper to replace before it fails completely and sends pieces through the system which could involve replacing more parts.
Charlie
#3444505 - 08/03/14 08:28 AM Re: Leaking AC compressor life.... [Re: gregk24]
Chris142 Offline
Loc: apple valley, ca
replace it now. if you wait and it burns up due to no oil it will get real expensive once it contaminates the whole system.it only holds about 5 oz of oil so any visible oil is bad
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric edge 5w40
#3444516 - 08/03/14 08:40 AM Re: Leaking AC compressor life.... [Re: gregk24]
Roadkingnc Offline
Loc: NC USA
I would fix it now, if it locks up the black death will spread throughout the whole system and it will cost a lot more to repair.
#3444530 - 08/03/14 08:53 AM Re: Leaking AC compressor life.... [Re: gregk24]
Cujet Offline
Loc: Jupiter, Florida
My Sanden compressor on my Jaguar X-Type has been leaking for the last 5 years. I need to top it off every summer now. Still blows cold here in South Florida.
You can probably get a name brand, exactly the same, replacement compressor on eeeebay for 1/4 the price a dealer would charge. It may not have the Honda tag on it, but it will be made by the OEM that provides the units to Honda and will perform/last the same.
The Chinese ones are to be avoided.
Turbo's rule.
#3444583 - 08/03/14 09:59 AM Re: Leaking AC compressor life.... [Re: gregk24]
JTK Offline
Loc: Buffalo, NY
If it does stop blowing cold (lost it's charge), I'd pull the a/c compressor clutch relay to keep it from trying to cycle.
Then get the a/c work done when you can.
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#3444590 - 08/03/14 10:07 AM Re: Leaking AC compressor life.... [Re: gregk24]
hsd Offline
Loc: NE
My 2000 Accords compressor leaked for a couple of years before needing a can of refrigerant. That was two years ago and it was still working fine when I sold it earlier this year, so they can run a long time or they may fail quickly.
I would follow your mechanics advice and run it till it dies. The freon will likely leak out and shut down the compressor on low pressure before it breaks mechanically.
#3444624 - 08/03/14 10:49 AM Re: Leaking AC compressor life.... [Re: Cujet]
Chris142 Offline
is it leaking visible oil like the op's?
87 F250 napa 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3444668 - 08/03/14 11:56 AM Re: Leaking AC compressor life.... [Re: gregk24]
Silverado12 Offline
Loc: Central Virginia
FWIW I've had a compressor come apart (internals knocked a hole in the case). If me I would have it replaced.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
15 Chevy Cruze 1LT auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
10 Mustang GT auto
#3444888 - 08/03/14 04:59 PM Re: Leaking AC compressor life.... [Re: Chris142]
Cujet Offline
Yes, there is always green oil on the bottom of the compressor. It's not a huge oil leak, but it does exist.
It takes about 1/2 can per year.
Turbo's rule.
#3444967 - 08/03/14 06:36 PM Re: Leaking AC compressor life.... [Re: gregk24]
Fleetmon Offline
Loc: Pa
A friend had his compressor deemed bad/leaking by his Ford dealer....I checked it over and it needed the AC control valve (rear of compressor) and vacuum/recharge system. It works fine to this day and no leaks. I think the green drip coming off the compressor was from the "technician" disconnecting his gauges.
"In order to become the Master, a person must act as a servant."
NRA Endowment Member
#3445019 - 08/03/14 07:39 PM Re: Leaking AC compressor life.... [Re: gregk24]
artificialist Offline
Loc: Florida
When the compressor fails, you will always be required to flush out the system, replace the drier/accumulator and the expansion valve/orifice tube anyway, so I would just keep using the compressor until it is completely dead.
2010 Lancer Ralliart Sportback
#3445246 - 08/03/14 11:43 PM Re: Leaking AC compressor life.... [Re: gregk24]
gregk24 Offline
Loc: FL, USA
Here is a question, if its just a slow leak...would it be smart to have the system "recharged"? And is a recharge just an extraction of old fluid and a fill with new fluid?
42,xxx miles
#3445254 - 08/03/14 11:58 PM Re: Leaking AC compressor life.... [Re: gregk24]
Nick1994 Offline
Loc: Phoenix, AZ
You can recharge it yourself with a kit from the auto parts store, now that is about as simple as pumping gas
2000 Toyota Camry 2.2L 222k
Mobil 1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 141k
Mobil 1 HM 10w30 & Wix
Page 1 of 2 1 2 >
