Originally Posted By: TiredTrucker
Just curious, as I have no dog in this hunt, but wonder how then that Ford specifies a XXw20 oil for their Ecoboost V6 with turbocharger if there is no turbo designed with using 20w oil in mind.[/quote
Just interested in what the Ford engineers were doing deisigning Mitsubishis and why they didn't advise them to use Motorcraft 5W20 in their Ford/Mitsubishi engines...
Unless Ford had nothing to do with said Mitsubishi engine, and the Mitsubishi engineers have their own designs and performance parameters...
TiredTrucker said:And since a lighter fluid sheds heat faster than a heavier fluid, why wouldn't the 20w be a good choice over a 30w, as long as the film strength meets the demands of the application?
How does a lighter fluid "shed heat" faster than a heavier...just in technical terms, specific heats, flow rates, stuff like that...so that we can quantify the percieved and much vaunted
(on BITOG) improved heat transfer capacities of 20s.
As to your films strength aassertion, you are falling into the one armed bandit mindset
Hydrodayanim lubrication has parts separated by a film/wedge of oil, the film stiffness and strength determined by surface speeed, bearing size, and viscosity...viscosity up, film thickness up, parts move further away from each other
When the oil wedge is gone, through too low a viscosity, or abnormal operation, you get into the realms of films strength that is determined by additives...this part has not much to do with viscosiy, however if you look up the liner scuffing paper that I posted a couple days ago,you'll see that a straight 40 could pass the scuff test, while a 10W-40 couldn't.
