Last week I changed the oil in my Renault Clio after rainwater went inside the engine when I was changing the timing belt. When I went to buy the oil at Autozone they gave me for free a generic filter that I thought I will end up using it eventually, but for that change I used the OEM filter that I already had. Upon closer inspection of the generic filter I saw that the threads had a lot of metal shavings, and I think metal shavings are not a good sign. So I decided to offer the filter as a sacrifice to the oil gods and compare it to the filter that I removed from my car.
The OEM filter was used for about 7,000 kms with Valvoline Synpower 5W-30. The dimensions are 8.0 cm of diameter and 5.0 cm of height.
Packages and side by side
OEM Filter. Renault branded but made by Purflux. The thickness of the canister was 0.68 mm, it has a spring loaded ADBV and chevron pleated media.
ADBV Detail
Generic Filter. Supposedly is made my Bosch. The thickness of the canister was 0.22 mm, it has a normal ADBV and normal pleated media.
ADBV Detail
Other difference that I found was that the central tube of the generic is larger in diameter (4.0 vs 3.0 cm)
The bypass valves seemed to be of the same diameter and open with the same amount of force but I didn't made a trustworthy measurement.
ADBV Detail
ADBV Detail
