I recently picked up an 89 D100 3.9 shortbed w/auto.The truck seems to run good but for 2 things, a high idle for about 15 seconds after it is cranked and the oil light flickers occasionally at low idle while in gear but the oil gauge needle stays in the 40-50% area of the scale.The truck apparently has around 120k on it,but the history of it is a bit murky. It had been purchased from a police seizure auction.The truck sat up a few(2-3) years before it was auctioned off.The purchaser replaced most of the braking system did a tune up and used it as a work truck for a year.He hit hard times and was forced to sell it.The interior is pretty good other than a 3 inch tear in the driver side seat cushion.The exterior has a dent above the driver side tail light and a small scrape on the passenger side of the bed.It definitely needs paint but there is only surface rust .
The engine has a bad valve cover leak,does not smoke but seems to burn a little rich.This is my first 3.9 EFI V6..I always had slant 6's and 318's in my Dodges.I'm thinking I may need to run a clean up oil change as the oil in it is very dark but still somewhat transparent.I may add some MMO or other cleaner for a bit and change the filter.
As a side note the filter on this engine is small,cross ref's with my Trackers 4 cylinder.Is there a larger filter that will interchange?Any suggestions would be appreciated.
So I have a v.c. gasket replacement and oil sending unit replacement(which seems more likely than an oil pump failure on these engines from my research) and a possible engine flush in my future.
For the follow up o/c I have Ace Hardware conventional 10w30 and 10w40,10w30 Maxlife semi synth,Pure lube semisynth 10w30 and 5w30,Kendall titanium 10w30,Smitty semi synth 10w30 and 10w40.Any suggestions?I'm leaning toward the Ace oil for 3-5k with a filter change midway and then move to the better oils.
The tranny shifts fine,fluid looks good.Brakes and steering are good,I may do a fluid exchange on them anyway.I plan on replacing all of the rubber line etc under the hood.Any other ideas?
Any personal anecdotes with this engine or type vehicle?
Thanks people.
Thanks people.
