Blackstone comments: This is an unusual sample because chrome is fairly high, though everything else looks good. Chrome can show ring wear, though with a ring problem we'd expect to see signs of poor combustion like excessive soot and a thick viscosity. The lab did not note any soot in the oil, and the viscosity is right where it should be. Insolubles show solids in the oil, and those also often read high with combustion problems, though your insolubles are fine. Universal averages show typical wear for this type engine after 6,700 mi on the oil. The TBN is okay at 6.0. Try 7K miles again.
Miles on oil: 7,000
Miles on Unit: 64,970
Makeup oil: 0 qts
ALUMINUM - 4
CHROMIUM - 9 (FLAGGED)
IRON - 29
COPPER - 2
LEAD - 1
TIN - 0
MOLYBDENUM - 56
NICKEL - 1
MANGANESE - 1
SILVER - 0
TITANIUM - 0
POTASSIUM - 2
BORON - 46
SILICON - 4
SODIUM - 1
CALCIUM - 1442
MAGNESIUM - 1209
PHOSPHORUS - 1235
ZINC - 1459
BARIUM - 0
SUS Viscosity @ 210°F - 72.2
cSt Viscosity @ 100°C - 13.54
Flashpoint in °F - 420
Fuel % - Antifreeze % - 0
Water % - 0
Insolubles % - 0.2
TBN - 6
Oil was in for 6 months and I used a Mobil 1 oil filter. Any thoughts on the chromium?
Miles on oil: 7,000
Makeup oil: 0 qts
ALUMINUM - 4
IRON - 29
COPPER - 2
LEAD - 1
TIN - 0
MOLYBDENUM - 56
NICKEL - 1
MANGANESE - 1
SILVER - 0
TITANIUM - 0
POTASSIUM - 2
BORON - 46
SILICON - 4
SODIUM - 1
CALCIUM - 1442
MAGNESIUM - 1209
PHOSPHORUS - 1235
ZINC - 1459
BARIUM - 0
Water % - 0
Insolubles % - 0.2
TBN - 6
