Food for thought: Since your battery is not dead there is a good possibility that you can salvage it with a little work.
Although they are labeled as Maintenance Free Battery it doesn't mean you can not service it.
Pop open the rectangular battery cover w/ a flat blade screw driver you will be able to see if the electrolyte (battery acid) is low or not.
If low, top it off with distilled or bottled water, hook up your battery with a trickle charger such as Battery Tender overnight.
I've done this with my own cars & have always managed to extend the life of the batteries NP.
