I recently put a 2008 Hyundai Elantra on the road that I purchased several months ago.
It has just under 29K original miles and still had the OE Hankook H426 tires. The front tires were worn and had wear on the inner edge so I ordered 4 Hankook H727s. (it seems the original owner never rotated the tires).
When I went to change them I realized that the OE original H426s on the rear were in excellent shape (probably had 65% still left and very even wear). I moved them to the front and installed 2 H727s on the rear.
All is well except that I find that there is a lot of 'tire drone'. It does seem louder on certain roads and at lower speeds (35-55mph).
Would you guys think it's the tires or are Elantra's just noisy?
I do plan on getting an alignment this week.....If worse comes to worse i can always install the other 2 H727s but it seems wastefull with all the thread left on the OEs.
Thoughts?
Thoughts?
