Originally Posted By: OneEyeJack
Red Line has some oils specifically for your bike. Since motorcycles use a bit less oil per change and are often not ridden as much as you drive a car spending a couple of dollars more for Red Line might be worth the trouble. From experience their oil works well in air cooled engines that sometimes see very high temperatures.
+1
I use Redline 20W-50 in the engine of my Harley 103, quieter and longer lasting than the Mobil V-Twin I had been running. Change at 5,000 miles but could easily go a lot further with the Redline.
Redline MTL in the Primary. Had been changing out at 5,000 miles. Will be going 8,000-10,000 miles as the oil is THAT good.
Redline Shockproof Heavy in the tranny. Quiets the clunk, easy shifting, easy to find neutral. Had been going 5,000 miles between changes. Oil looked like new so now I'm going to 10,000 miles on the tranny change. Could easily go a lot longer!
