Originally Posted By: JHZR2
But the magnetic field won't be as strong down the length of the plug vs if the magnet was in the oil.
Exactly right, the magnetic field is "shorted" by the metal oil sump pan, the field will be fairly weak inside the oil pan, despite a strong magnet on the outside.
It is best to put the magnet inside, where the magnetic field will do the most good , be strongest. Small magnets can be near useless on the outside.
The stonger the and larger the magnetic field, the more likely it will catch junk in the least number of passes of oil thru the system.
i pulled two petty darn strong magnets out of an old microwave oven's microwave tube assembly.
