oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
100 registered members (4WD, anndel, aba4430, aquariuscsm, 2004tdigls, 240_Ed, 14 invisible), 1,828 guests, and 39 spiders.
Topics295,018
Posts4,926,070
Members66,666
Most Online2,553
Oct 27th, 2018
2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi #2938891
03/14/13 05:04 PM
03/14/13 05:04 PM
Wichita Falls, TX
86cutlass307 Offline OP
Wichita Falls, TX
First sample for this Tacoma 2WD rear differential. Please comment as I need to understand better the lab's Phosphorus comment and Redline gear oil. Factory fill was changed at 11,376 miles. Total miles at sample time was 39,266. Flagged data was the phosphorus level. Viscosity seemed in line with Redline's data.
Lab comment - "Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor equipment and fluid conditions. Phosphorus is slightly high for this lubricant. Lubricant change acknowledged."
WEAR METALS (ppm)
Iron - 41
Chromium - 0
Nickel - 0
Aluminum - 0
Copper - 0
Lead - 0
Tin - 0
Cadmium - 0
Silver - 0
Vanadium - 0
CONTAMINANT METALS (ppm)
Silicon - 14
Sodium - 8
Potassiium - 0
MULTI-SOURCE METALS (ppm)
Titanium - 0
Moly - 1
Antimony - 0
Manganese - 0
Lithium - 0
Boron - 378
ADDITIVE METALS (ppm)
Magnesium - 0
Calcium - 15
Barium - 0
Phosphorus - 3002
Zinc - 11
Water - < .1 - Hotplate
Viscosity @ 100 C - 16.5
Acid Number - .60 mg KOH/g
2014 Honda Accord EX-L, CVT 4 cyl.
2009 Toyota Tacoma TRD Sport 4.0L
1986 Olds Cutlass Supreme Brougham-2nd owner (rust free)
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: 86cutlass307] #2938940
03/14/13 05:43 PM
03/14/13 05:43 PM
NE
jegs Offline
jegs  Offline
NE
Phosphorus is part of the additive package in the oil. Since Redline is geared towards racing I'm not surprised it's slightly higher than other gear oil. Nothing to worry about. The wear metals look good. Your diff should live a long and happy life.
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: 86cutlass307] #2939296
03/15/13 03:45 AM
03/15/13 03:45 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
I hope to goodness you didn't OCI with this UOA, did you?
Generally, once you flush out the FF, gear lubes can stay in a long time; especially syn choices.
Overall it looks fine.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: dnewton3] #2939301
03/15/13 04:03 AM
03/15/13 04:03 AM
Wichita Falls, TX
Wichita Falls, TX
I took the sample through the fill port using the trusty siphon tube; Redline is like gold. Anyway, lube still had its amber hue at this sampling so I was hoping to let it ride. I have had several long highway trips over the last couple of years and was curious how the gearset is beginning to age. Overall I'm pretty happy with the lab results. I'll say the silicon was due to the windy/dusty day in North Texas on sample day for my peace of mind. This differential and my driving habits seem to be a good match with this Redline lube. As said above, should live a long and happy life.
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: 86cutlass307] #2939317
03/15/13 04:41 AM
03/15/13 04:41 AM
Magnolia, TX
INDYMAC Offline
INDYMAC  Offline
Magnolia, TX
Thanks for posting. This is the first RL 75W-90 UOA that I find inspiring. Did you top off after taking the sample?
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: INDYMAC] #2939421
03/15/13 07:30 AM
03/15/13 07:30 AM
Wichita Falls, TX
Wichita Falls, TX
Yes, I let a few seconds worth drain out before the capture. I had some left over from the change back at 11K and just topped up. I tilted the axle ends to let the fluid level run down the tubes and stopped when the fill hole started a drip/run. Should be good for some time to come, seems stout for a street truck lube.
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: 86cutlass307] #2939528
03/15/13 10:03 AM
03/15/13 10:03 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
41ppm Fe is pretty low for a diff, but then your sample duration is also low, hence your wear/mile is fairly normal.
Great to hear this was a sample and not an OCI.
No reason not to continue this run!
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: 86cutlass307] #2939641
03/15/13 12:20 PM
03/15/13 12:20 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I wouldn't worry too much about the silicon since RL uses about 8-15 ppm of silicon in their formulations.
The phosphorus is most likley part of the Sulfur-Phosphorus Extreme Presuure additive.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: 2009 Tacoma Rear Diff UOA Redline 75w90 27,890 mi [Re: 86cutlass307] #4675103
02/23/18 07:05 AM
02/23/18 07:05 AM
London, UK
Izb Offline
Izb  Offline
London, UK
What potential harm (for example for oil seals) can be from a high level of phosphorus?
