Looking for an oil recommendation;
I have a 2011 LML duramax, approaching 35,000 km (20,000miles). The dealer performed the first 3 oil changes as part of my sales neg. From now on I will do the DIY oil changes. Looking for a recommendation. I'm from Canada and have easy access to Shell, Esso, and Petro Canada oils, as well as everything else out there.....
FYI. This truck has the EGR shut off, and the DEF/DPF/SCR removed, whether or not that will make a difference on oil selection???
Also, my preferred maint on all my vehicles is to change the oil twice a year, spring and fall, which = 12,000-15,000km (8000-10000 miles) on each change.
thank - you.
thank - you.
