Originally Posted By: alleyhunter
Hey there,
Recently salesman at a used car dealership told me that their techs can inspect a car and be able to tell if the previous owner's kept up with the oil changes.
Is that true?
David
True to a point, but would you actually take the word of a used car salesman? Having worked in car sales I can tell you this: There are cars where it is nearly impossible to check if the oil was changed unless you pull a valve cover or drop the oil pan. Some of these chores are very costly, and not done when checking a trade or used car the dealer takes in. Cleaning a dipstick is not very hard, and a clean dipstick with a fresh fill of oil can often hide what's really going on. Every car we sold was detailed, had the brakes checked, and got an oil change before it was put on the line. Ticking or knocking trades that slipped by the manager were often dosed by the shop with LOS to quiet them down. Let the buyer beware. Check the car yourself or have your own shop do it before buying, but even you can have problems.
