Originally Posted By: jstutz
I have a GT2544 with a kohler command 20 in it. Not sure exactly what the difference between the command and courage is.I have run 5w40 and 15w40 in it for the last 5 years. Mostly 5w40 but at least two summers on 15w40. I also run it in the winter alot. Mostly 30s and 40s. When we ever get snow, i have it out pulling the kids on sleds and stuff. If you dont plan in running it in the winter, I dont see any reason at all you cant use your 15w40.
I ran 15w40 in my 2544 as well.
Even though the OP's 20hp is a Courage single cyl which are a design all their own, I'd personally still run 15w40 in it over a normal passenger car 10w30. If you have 10w30 HDEO on hand, that's great too.
OTOH.. I don't get the fears people have with cold start issues using 15w40? 15w40 is a 15w for cold starts where SAE30 is molasses.
Joel
