2007 mazda 3i, daily driver, 55k miles of regular driving (not aggressive), mix of local and high way.
two front tires currently have about 10k miles on them, they developed a heel-toe wear pattern on the outside shoulders.
driver side rear tire has an interesting alternating tread block wear pattern (not the passenger side rear though).
car has three alignments done over 5 years, suspension is tight, bearings have no play, wheel hub run-out is within spec., so I am at a loss finding the culprit of the wear.
Some say the heel-toe wear is normal, so I swapped the fron tires left-to-right on the front.
As for the rear tires, for some time, my passenger side tire had a slow leak, so tire pressure was lower than the one on driver side, but not greater than 6psi, otherwise the TPMS light would be on. no problem that I can see on the rear shocks.
Any thoughts? thanks.
PS. I also checked both front and rear sway bar and links, they are fine and positioned properly.
