Used many types over the years and have never found one I really like. Saw on ADVRider where some (quite a few) use ATF and state it works very well.
According to the the chain manufacturers, gear oil is preferred, an 80-90w. I would assume this is for the 'pressure' handling equation vs heat.
My question is, out of motor oil, gear oil and atf, which handles the punishment a drive chain encounters best, all the while keeping the chain clean and lubed at the same time?
