My Troy-Bilt 2 stroke as a whole? About 1 month.
The gear drive at the end of the shaft locked up completely.
Replacement took a couple of days and the small engine shop had to go by production date since Troy-Bilt had not bothered to process my warranty registration by then.
The new gear drive was just as noisy as the old one had been. Took it apart, cleaned out the old grease, repacked it and haven't messed with that end of it since.
The powerhead has been reliable....I'll give it that. It's seen years of service in every condition from easy edging around my house to heavy overgrowth clearing and saplings behind my shop.
It is reliable. But that does not mean it is pleasureable to use.
It is literally 10X harder to start than my Echo blower. I mean you literally have to do 10 more things to get it to kinda' run on half choke until it's warmed up. It vibrates so much more than my neighbor's Stihl. And it's louder.
I anticipate no less than 10 years of service out of it. I sort of want it to die now though because I have used better equipment. It's just so disappointing knowing that I do not have to deal with the whole rigmarole of getting it started and the vibration and noise. I'm not going to let it die prematurely by neglect but I'm not going to fix it when something substantial fails.
