In installing a sensor for EOT, it's common to measure the sump temp. That's how I have done most of my installations. I wonder if anyone (in particular you CATERHAM) have any thoughts about other point to measure EOT that more accurately represents the higher stress point in the engine where oil temps might be higher? Seems to me, the sump oil is cooler that the oil in a hydrodynamic wedge at the bearing or drooling out after doing its job. I wouldn't think measuring in the OP circuit, say the main gallery, would be much different than the sump. A sender in the main cap might not be accurate because it would pick up combustion heat transmitted through the block. Maybe the sump is the best place and what I need is some idea how much hotter the oil might be running in other areas... which I have seen somewhere.
