Originally Posted By: Bluestream
Originally Posted By: Donald
And you should test it to be freon before doing anything. Jiffy Lube will not work on a vehicle if their test says its not freon. (Not that I am a fan of Jiffy Lube). Some shady places (not to be confused with a shade tree mechanic) have put in butane or propane and it works fine until?? They pull the freon and keep it. And they might have been doing an oil change when they pulled the freon. As the price of freon climbs, this practice will be more common.
By Freon, I assume you mean R12. Very few vehicle are left on the road use R12. It may be expensive, but there's not much demand for it anymore.
As for stealing R12 and replacing it with another gas, that would be very illegal and I high risk activity for any shop to engage in.
"freon" as in R12 has come down quite a bit in cost.
In any car requiring it, I would stick with R12 after fixing whatever leak may exist.
None of those pumps are very good, but I wouldnt want to be burnining up my air compressor when vacuuming an AC system (since I like to pull vac for a LONG time).
Id find a US-made version of #2 and go with it.
If the work really is seldom, and given the complexities of evacuating and all, Id let a shop do it. It is highly illegal to release ay refrigerant into the atmosphere.
