Hey Yall,
Anyone else here use Lucas Oil Products? I currently use the Heavy Duty Oil Stabilizer on 3800 GM Engine w/180k miles mixed with 4qts Mobil 1 10W30. Although the 3800 is an excellent engine by itself i have noticed the Lucas Oil stabilizer to have quieted the lifters and lessen oil burning.
I did run the stuff mixed with Royal Purple in the same ratio on my 50k mile Camaro...BUT
on the Camaro it crashed my Fuel Economy 4mpg!!!!
According to Lucas Oil Tech Support they said my bearings/rings were in new and likely to close to factory tolerances which did not work to well with the heavy viscosity Lucas. Curious Point if anyone has experiance with this stuff.
I also use thier ATF Transmission Slip, Power Steering and Fuel Cleaner additives.
-Sun
-Sun
