Originally Posted By: MNgopher
This is another area (similar to just about any ethanol thread) that some folks are only going to see what they want to see. I again state that without holding every other variable constant, one will have a hard time seperating the effect of winter fuel (which by itself is an interesting question) from all other affects, mostly temperature related.
Fuel in our market does not have a single switch that gets flipped from summer to winter and back. One measure of winter fuel is the maximum RVP (Reid Vapor Pressure) allowed. This is a measure of the volatility of the fuel. A higher RVP helps cold winter starting, but also means that lighter , cheaper feedstocks can be used.
Here are the dates of changes in our market:
March 1st: Max RVP 8.5
May 1: Max RVP 9.0
Sept 16: Max RVP 10.0
Oct 1: Max RVP 11.5
Nov 1: Max RVP 13.5
Dec 1: Max RVP 15.0
Feb 1: Max RVP 13.5
Feb 16: Max RVP 10.0
Note there is a ramp up and a ramp down. We already started ramping down here almost a month ago. (The March 1st number is slightly lower to ensure that any residual stock with higher RVP's when blended comes down to an RVP of 9.0 or less). Not every market operates this way, but it again raises the point, how do you know what fuel exactly you are buying and comparing? Winter fuel? Sort of winter fuel?
Awesome post!
I notice a difference as well, but I've also got all of these gears sloshing around cold oil in the winter time. Also, as much of a proponent of drive-to-warmup, I'm sure that I still allow more time in the winter, especially during cold days. This, combined with a cold-start enrichment are what I'm guessing eat up the extra MPG's. Whether winter fuel has any appreciable effect I have no idea. Combined with all of the aforementioned, it could very well be true that I'd see and INCREASE in MPG's if I ran winter fuel in the summer time (never you mind the additional venting of the more-volatile fuel! haha)
