JHZR2
Staff member
When below 45F, and especially below freezing, my 91 BMW 318i has a lifter tick. Sounds like a sewing machine, and goes away after about two minutes of driving, during which I try to never go over 2000RPM.
I've tried a bunch of things - 0w oil, neutra, kreen, zmax, LM MoS2. All had some quieting behaviors, but none lasted.
So I'm just sticking with M1 10w-40.
But I have a few questions:
-I've heard lots of folks say that they've driven for years with a tick. I've also read that driving with a lifter that doesn't take the valves up properly is a recipe for a burned valve, since the valve will not be traveling its correct distance. Which is the case?
-Is it prudent to replace only one lifter (if you can find which one it is), or must you do all 16?
- How do you determine which is ticking?
-Does this job require removal of the head?
- is this job a DIY without special tools? Like remove the VC, unscrew the bearings holding the cams down, pull the cams, extract the lifters, then replace and torque down back together?
Thanks!
Thanks!
