Originally Posted By: bdcardinal
On the Ford Modular side of things there is actually a tool that you screw into the unused port on the oil filter housing that shoots pressurized oil into the engine for initial startup. Ford Racing Performance Parts sells the tool and it is fairly inexpensive.
An old Bug sprayer cleaned and filled with clean oil and the correct adapter to fill the oil gally's up works well too.
