Originally Posted By: dakota99
For what it's worth concerning the high mileage seal issue, my rear main leaked almost enough to make a traveling line on my garage floor while using M1HM 10w30. I switched to platinum and after the second interval it's been reduced to almost two drops after being parked. I have no clue why it leaked more on the high mileage.
The rear main seal falls under gasket, and depending on its composition, high mileage oils would have no effect. I think your situation is the gasket is failing, and you require a thicker oil that doesn't have a high detergent level. Sometimes a little sludge plugging the hole is a good thing.
Whats interesting is both oils claim high detergent levels. Platinum claims the highest detergents of its product line and competitors. Most people in here agree. You claim after 2 OCIs the leaking slowed with the platinum. I remember years ago people claimed Mobil 1 made seals and gaskets leak, but that was back in the PAO days. Don't hear that anymore.
So the facts are the Mobil 1 can get through the rear main gasket hole where the Pennzoil can't, and your leak is getting plugged somehow over time using platinum. Hmmmm..
