T-Keith is correct. With this transmission you should be able to get about 7 out a the 10-10.5 quarts by just doing a pan drop.
JOD - No plus in this pan. The filter can be found at Advance Auto Parts or the dealer. The gasket is reusable and much nicer than the rubber in cheap replacement kits. The AC Delco kit won't even include a gasket.
