Unfortunately, changing the oil may help some, but this is as you might call a design flaw with DI engines. Using a low volitile oil will help some, but you will always have some "oily Vapour" come through the crankcase to the intake via the PCV system. You just cant avoid it.
A catch can system will help with the issue, but it wont catch the vapour will will cause the build up, albeit at a slower rate.
And you can run 110 octane jet fuel with 6 gallans of Techron, but remember that the fuel by passes the intake and is injected directly into the cylinder, not touching the carbon buildup.
you need manual cleaning or sending some cleaner right into the PCV system that way, you incorporate some cleaner into the incoming air mixture, hitting the buildup and getting some cleaning action.
back in the day, the old school mechanics used to pour water into pcv systems to clean carboned engines. the water would hit the carbon, cause it to break apart and get blasted out the exhaust system. maybe a cheap way to get cleaning especially if Audi is calling all this as part of regular maintenance.
sorry guys, but no DI engine for me
