AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
27 registered members (CharlieBauer, carlprop, cjolson140, BrandonT, aleneros, 3 invisible), 810 guests, and 18 spiders.
Topics297,569
Posts5,118,190
Members69,899
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: wallyuwl] #2213981 03/27/11 05:04 PM
M
mechtech2 Offline
M
The mating surfaces have to be clean and dry.
A small dab of silicone RTV is usually used in the corners or at half moon seals - things like that.
Use a new gasket, for sure.
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: Bill in Utah] #2214278 03/27/11 09:37 PM
H
HTSS_TR Offline
H
Originally Posted By: Bill in Utah
I've got the same engine with 196k and the only things I've done so far to it is;
1 PCV valve
Oil changes
Air filter changes
1 coolant flush
1 set of plugs
That is it. Everything else is still sealed up and original. I bought a valve cover gasket a few years ago when I check the valves, got a accessory belt when I need to replace it and I know its clean so until something needs to be taken care of I'll do it then.
No WAY would I be replacing the O2 sensors, cat and such unless I NEED to. Is there a problem that you need to take of the intake?
Here is my oil fill 5 minutes ago. I'm not concerned...
Keep us informed.
Bill
Almost 200k miles with only 1 coolant flush ? The first coolant flush should be around 100k miles and every 60k miles after that, is that the recommended ?
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: HTSS_TR] #2214288 03/27/11 10:03 PM
H
hate2work Offline
H
IIRC, Bill used Peak Global. Between that and the distilled water, the total was less than $20.
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: Trav] #2214292 03/27/11 10:05 PM
defektes Offline
Originally Posted By: Trav
Quote:
I think I'll get an OEM gasket (depending on price) instead of a FelPro one
FelPro makes and excellent gasket,no reason to spend more money.
Agreed, fel pro is on par with OEM.
2002 GMC Sierra 5sp. 4.3L 145K ST3980 E-Core
Chevron Supreme 5w-30, Amsoil Synchromesh In Tranny
Valvoline SynPower 75w-90 Gear Oil In Rear
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: HTSS_TR] #2214303 03/27/11 10:31 PM
Bill in Utah Offline
Global Moderator
Global Moderator
Correct. Here is the tread on my coolant change a little over 150k.
Correct. Peak Global lifetime is in my Toyota, Subaru, 2004 GMC truck, Dad's 2005 Honda powered Vue, 2002 Chevy truck, 2005 F150 and 2007 Dodge Caravan. Going in my sisters 2003 Taurus next month. I'm not going to have 6 different coolants I have to keep track of.
As far as the next time I'll change the coolant is a drain and fill every 2-3 years with 50/50. Once I did the full flush to get the vehicles over to PGL a drain and fill is all they will get.
Take care, bill
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: wallyuwl] #2214845 03/28/11 12:59 PM
R
Rix Offline
R
Use the OEM v.c. gasket if you can, TRUST ME< IT'S BETTER.
No need to hold it in with anything, it'll stay in if you lightly tap it into the valve cover.
If you have no codes for o2 sensors or catalyst efficiency, LEAVE THEM ALONE. If you put an aftermarket cat in that car, you'll soon have a check engine light because of it. Aftermarket cats are not up to par with the oem part.
Change your fluids, plugs, (use NGK or DENSO), PCV valve, clean the mass air flow sensor with brake cleaner (or other solvent that completely dries and leaves no residue) and don't overthink that car.
It's not an old caprice that needs all that stuff.
You might look around and see if your car is involved on the A0J ECU replacement.
Information is power. Factual data is ammunition.
Re: Vibe/Matrix/Corolla 1.8 1zz engine valve cover [Re: wallyuwl] #2214848 03/28/11 01:02 PM
R
Rix Offline
R
Oh.... and spray some intake cleaner/carb cleaner type stuff into the throttle body. (throttle body service)
Page 2 of 2 1 2
