I has no issue with ANY of the so-called coolant chemistry's. Use the Zerex, Peak, or Prestone...
All you have to do is maintain your system with a little more frequency and you can use just about any coolant.
The biggest problem with long life, extended life, super long life, eternal life, last forever....coolants and antifreeze is that they are NOT that good.
My favorite issue with older Nissans was that the factory fill was good for 60k, but all future maintenance, even with dealer coolant, was at 30k intervals after the 60k run. Cracked me up. They couldn't explain why either. But, I'll give you a hint. The 60k factory fill run clogged up your system, and the future 30k services did what it could to try to prevent complete failure.
Thermostat accuracy is also questionable after 5years/100k miles. So, have it replaced also.
