Originally Posted By: 5sfe91
Has anyone cut open a Pronto oil filter are they worth a try?
Heard anything bad about them?
I can get 7 filters shipped for under $20 thats 35,000 miles worth of filters!!!
Originally Posted By: labman
I put my first Pronto on my truck in December, and plan to leave it there longer. It was made in America by Clarcor. Unfortunately, I have heard they have gone Chinese.
I have used a variety of other Pronto products in the past and had good luck with them. They are a buyers group. The Pronto jobber here is the leading auto parts store in town, where the pros go, not a DIY place like AAP or AZ. It is a name I trust.
Well I finally did. I got around to cutting open the Pronto filter off my truck tonight. Not much special. After a year, the nitrile ADBV was still nice and soft. The media was somewhat wavy, likely more a problem with moisture in the oil than the original construction. The truck sets a lot and does a lot of short trips. Maybe I need to get a sample off to Blackstone and makes sure it isn't coolant. It had about as much media as anything has any more. Since I first started cutting filters open over 10 years ago, I have noticed less and less filter media. Could mean they are cheapening them, or less of a better media. The newer filter designs have less media than the older ones. The very low stressed engine in my truck originally used a PF 9 with more area than anything. The Iron duke in my daughter's Berreta used a smaller PF52. The highly stressed HO Quad 4 in my Grand AM used the next smaller PF 47. I am pasting in data I have been collectign for a long time if anybody is interested. Any fool with a hacksaw and tape measure can determine how much filter area a filter has. How much difference that makes? Who knows? You can also tell what the end cap is made of for what that is worth.
I went back with Mobil 1 0W-30 and a NAPA Gold filter, perhaps my last one. Dome end bypass and a bad thread. I had to clean it up before I could get started on the nipple. Neither Wal*Mart or anybody else here stocks any 0W-30. Had to hit an out of town Wal*Mart. Wanted to let people know how my Pronto did.
Brand-----P/N----Length width area Fits---endcaps---mfg--valves
Older data, 2000 ?
AC Delco--PF9-------102 2 1/2 255 77 LUV
STP-------S02856A---108 1 3/4 189 ''
Purolator L10193----105 1 3/4 184 ''
Power Flo SL14619----76 2 3/8 180 ''
Hastings--LF143------71 2 1/2 178 ''
ST--------ST3950-----98 1 3/4 171 ''
Fram------PH 3950----48-1 3/4--84 ''
2003 filters
Miata-----B6Y214302--69 1 3/4 121 1991 Roadster
AC Delco--PF2244G*---46 3-----138 02 Cavalier--------France
STP-------9018-------57 2 1/2 143 ''-----------------Korea
Purolator L15436-----52 2 1/2 130 ''-----------------Thailand
WIX 57082 Never got around to measuring it.
22 Aug 03 filters were a year or 2 old
ST--------ST3950-----84 1 3/4 147 77 LUV--------metal---------ADBV bypass
Purolator L10193**---76-----2 152 ''-------------card USA '' ''
Purolator L10193-----96-----2 192***''----------metal India '' far end
AC--------PF1177-----92 2 1/2 230 ''-------------card Canada ''
AC--------PF 47------56-----2 112 92 GrandAm----metal ''
AC--------PF 52------53 3 3/4 198 '' OS---------''----''
ST--------ST 3387A---46-----2--92 '' ''----------------USA ''
ST****----ST3950-----90---2.1 189 77 LUV--------Metal--------ADBV, bypass
ST 6-05---clicker '' 90 1 3/4 157 ''------------------------''---USA--ADBV, bypass '' ''
Purolator 9-08 L10193 64 1.75 112 ''--------''---USA--ADBV, bypass '' ''
2009 data
Purolator L10193-----75 1 3/4 131 ''-------------''---USA--ADBV, bypass '' ''
MicroGuardGL10193----64---1.6 102 77 LUV--------metal USA ADBV, dome
STP-------SO3950-----73 1 3/4 128--''-----------metal USA ADBV, dome
AC--------PF457------64---2.3 147 02 Cavalier plastic USA no valves (Hengst)
Dynalube--D5436------59--2.25 133 02 Cavalier plastic China
2011 data
Pronto----PO 3985--48.5-2.375 115 77 LUV--------metal USA ADBV, Dome (Hastings)
*The AC, Hastings, and Fram all said PURFLUX L264A on the end of the plastic housing.
**Interesting 1 piece of rubber for both valves
***The media was noticable thinner than the others
****9-04 newer black case
Edit/Delete Message
