That is scary. Has your friend ever sheared off an oil pump drive? How many starters does he go through? How DOES that thing crank?? If he insists on running that heavy of an oil year round, maybe try Mobil 1 15W-50. Mobil used to claim the 15W-50 Borderline Pumping Limit was -35 F, with a pour point of around -45 F. If the winter conditions are anything like North West Ontario, Manitoba, Saskatchewan, or Alberta, I would run a decent 0W-30 in winter and a heavier oil of your choice in the hot summer months when you're towing or stuck in traffic with the A/C at full blast.
