OK -- this is a weird one. My Focus interferes with my garage door opener. My garage door opener is less than 5 years old (Chamberlain screw drive). I have to literally press the remote button 10-20 times before it closes -- ONLY when the Focus is running. At first I thought it was Sync(Bluetooth) or Sat Radio related -- because my previous ride didn't have those features. However, I've turned all that off, and I still can't open/close the door w/o pressing it 10+ times. Turn Focus off, and it works the first time -- every time. It's really annoying! I have no problems using Homelink in my other ride, nor did I have problems with the same remote in my previous Ford (Sport Trac). Garage door openers operate in the 300-400MHz range, so I can't figure out what could be interfering with it. The problem didn't appear immediately after buying the Focus. A bell just went off: I did add an aftermarket amp -- which is always on when the car is on. I could try pulling the fuse in it -- long shot -- but that's the only thing changed.
