Normally, I'm a hot oil change guy. I change the oil after driving. My most recent oil change I did after the car sat overnight.
When removing the oil filter in a hot oil change, a substantial amount of oil runs out (some from the filter, but I think a fair amount from inside the engine).
I noticed with the cold oil change that nothing ran out from inside the engine when I removed the oil filter. There was some oil in the filter, but not as much as when doing a hot oil change.
Is this to be expected, or has all the oil drained past the anti-drainback valve in the filter (or is it normal for oil to do that anyway after the vehicle had sat for a while).
The vehicle in question is a 2006 Lexus RX400h. The filter was the Toyota filter.
