Hi everyone.
I own a 1.4 VW engine (AUB code - 101bhp) bought with 87k miles on it.
It takes 3.38 quarts of oil to fill the engine.
Not knowing this car background, i did a flush using pro german brand SONAX and changed the oil with Shell Helix Ultra 5w40.
(sold in US as Pennzoil Ultra)
I used this oil mainly because its VW50200/503.01 grade and was not expecting oil consumption..
But it went thru around 1 quart of oil in about 600 miles..
Manual states that up to 0,5 quart oil consumption is considered normal..
But that does not explain why quite a lot of other owners with the exact same engine are able to go up to 9.000 miles with NO oil consumption.
Took it to a local dealer, no oil leaks detected, compression test was 14,5 - 14,5 - 16 - 16, even higher than the 10,5 VW says it should be.
Engine revs up fine, plenty of power, no smoke that i can see, no oil smell..
Don't know if i have a sludge issue, i only did an engine flush to be on the safe side.
First with SONAX, a german kerosene/xylene based flush, 10m@idle.
Then another one with Shell Helix Ultra 5w40 already in the engine and after 1200 miles (and almost 2quarts worth of top up's), with Xado specific "Vitaflush", driving 120 miles
with it as XADO instructions stated, before changing to thicker Castrol mineral GTX 15w50 with the xado cermet inside.
I kept the "old" (1200 miles) oil filter, allowed the remaining oil to drain from it completely during several weeks and measured its weight after.
It was 2.47 ounces heavier compared with a same brand new..
So 2 engines flush's in a 1200 mile period.
XADO cermet did not worked either, even with a thicker oil.
Also read here in BITOG were Dr. Haas research was mentioned, that a thiner 30 weight oil could have a better result in reducing oil consumption thru the rings, although that does not make much logic to me..
I have no ideia what's causing the oil consumption, but the faster i run the car, the faster it goes thru the oil..
Tried Castrol GTX High Mileage 15w40 mineral oil but oil consumption increased to 1qt/400 miles.. so this oil is not a valid solution in trying to slowdown consumption rate.
Based on all the knowledge here in BITOG, what properties should i look in the next oil choice, until i have the money to get the piston rings replaced?
Can i reduce engine oil consumption by choosing an oil that "buys" me both the time and peace of mind as far as engine health goes, until i'm able to tear the engine apart?
