Originally Posted By: TugaSaudade
Hello bmwtechguy
demarpaint shared with mw a study Shell did and they found that a thinner 5w20 oil had a higher film strenght in the top ring area compared to a 5w40 and a 15w40 and thus less oil consumption, IF it was related to the top ring..
I´m aware consumption could go up, but even if it does, it was time to put some more oil in anyway.
And since i'm hoping to replace the PCV valve in September (local vw dealer claimed they had to first order it from VW Spain and is short staffed in august), it will work as a "before and after" test comparison.. a way of measuring difference (if any) in oil consumption after it is replaced..
And being a low saps oil, it will (i hope) poison the cats at a slower rate until i find and fix the problem.
After whatever mileage i get this time, i'll see if i can smell signs of fuel dilution in the dipstick..
Makes sense to you?
Interesting. Mine is spec'd for 5W30 (or 10W30 in warmer climates), but that was back in 2000 when 20 weight oils were more of a niche market. Toyota has since moved to spec'ing them on newer models.
I've debated trying a 0W20 oil. I'd prefer thinner over thicker (IMHO thicker for oil consumption reasons alone is just treating a symptom while making the underlying cause worse, and maybe shortening engine life as well - just an opinion). I'd like to try Redline xW20 as, viscosity wise, its a thicker oil that's closer to a xW30 (I can't recall offhand if the oil in question was 0W20 or 5W20). It would let me transition toward a 0W20 oil without taking the plunge all the way with one of the thinner 20 weight oils.
It also has a very good detergent package as well, which is another big bonus for me. I haven't taken the plunge because of price: I've never found it on sale, and where I have found it, it was available in only 1L bottles @ $14 a bottle. $56 (for 4L) is too much when I can get Syntec (my most recent oil purchase) for $26.88 for 4.4L.
So it makes sense to me, and if you try this I'd be interested in finding out how well it worked for you.
-Spyder
