Hi, I just purchased a 2001 Buick Century with the 3100. It is supposed to be pretty common to have a knocking sound on a cold start up. From everything I have read it suggests it is caused by the pistons being to short and possibly carboned up causing piston slap. The noise is quite loud at first and after a few minutes goes away for the most.
The other day I was looking through the oil fill cap and could tell the noise was in sync with the valves. If it was piston slap wouldnt it be twice as fast as the valves?
If it is in the valve train what should I try doing? MMO or seafoam in the oil?
Maybe 0W30 oil or is this to thin?
Or 15W40?
It calls for 5W30 in winter and 10W30 in the summer.
Thanks
Or 15W40?
Thanks
