This is a current and on-going issue with a friend's car. They approached me today at 9 am and wanted me to take a look at their 2003 Impala with a 3.4L. The LIM gasket was just replaced along with the transmission flushed. The transmission pan gasket was leaking, so they had the place re-do it under the 12 month/12,000 mile warranty that comes with the shop's work. The engine oil was full when I checked it.
His wife drives the car every day on the interstate around 65 mph. She's been complaining about it shifting a bit rough and a lack of power.
I drove it and the throttle feels a little touchy, but that could be because I'm not used to it. It also shudders when it shifts, and this is much more pronounced under constant throttle and driving up hill, so load is increased.
I plugged into it, and there are no traditional trouble codes--no lights on the dash.
There is a current enhanced, manufacturer-specific code of P1189 which translates to "Engine oil pressure switch circuit."
This same P1189 is also present in the "Fail Since Clear" category along with a P1811 which translates to "Long Shift & Max Adapt" code.
Both the P1189 and P1811 appear in the history codes section too.
Thoughts? Debate! Thanks!
